Configure the Fast Advertisement Interval to send VRRP advertisement messages. The interval can be between 200 and 1000 milliseconds, and it must be the same on all participating routers. The default is 200. Enter the values in multiples of 200 milliseconds.
  1. In the navigation pane, expand Configuration > VLAN.
  2. Select VLANs.
  3. Select the Basic tab.
  4. Select a VLAN.
  5. Select IP.
  6. Select the VRRP tab.
  7. Select Insert.
  8. Select FasterAdvIntervalEnable.
  9. In FasterAdvInterval, type a value using multiples of 200 milliseconds.
  10. Select Insert.
