Configure ACE Internet Control Message Protocol (ICMP) message type entries to have the filter look for packets of a specific ICMP message type.
  • The ACL exists.
  • The ACE exists.
  1. In the navigation pane, expand Configuration > Security > Data Path.
  2. Select Advanced Filters (ACE/ACLs).
  3. Select the ACL tab.
  4. Select the appropriate ACL.
  5. Select ACE.
  6. Select the appropriate ACE.
  7. Select Proto.
  8. Select the Icmp Msg Type tab.
  9. Select Insert.
  10. Specify the operator for the ICMP message type.
  11. In the List box, specify the ICMP messages to match.
  12. Select Insert.
Icmp Msg Type Field Descriptions
Use the data in the following table to use the Icmp Msg Type tab.
Name
Description
AclId
Specifies the ACL ID.
AceId
Specifies the ACE ID.
Oper
Specifies the operator for the ACE protocol ICMP message type. Equal (eq) is the only option.
List
Specifies the ICMP message type (0–255), or echoreply, destunreach, sourcequench, redirect, echo-request, routeradv, routerselect, time-exceeded, param-problem, timestamp-request, timestamp-reply, addressmask-request, addressmask-reply, or traceroute.
