BFD provides a failure detection-mechanism between two systems. Use the following procedure to enable and configure BFD for an IPv4 interface on a VLAN.
  1. In the navigation pane, expand Configuration > VLAN.
  2. Select VLANs.
  3. Select the Basic tab.
  4. Select the VLAN on which you want to configure BFD.
  5. Select IP.
  6. Select BFD.
  7. Select Enable.
  8. Optional: In MinRxInterval, specify the minimum receive interval.
  9. Optional: In TxInterval, specify the transmit interval.
  10. Optional: In Multiplier, specify a value for the multiplier used to calculate a receive timeout.
BFD Field Descriptions
Use the data in the following table to use the BFD tab.
Name Description
Enable
Enable BFD on the VLAN.
MinRxInterval
Specifies the minimum interval, in milliseconds, between received BFD control packets that the local system is capable of supporting. The default is 200 ms.
Note:
The minimum value you can configure for the receive interval is 100 ms. You can configure a maximum of 4 BFD sessions with the minimum value for the receive interval. You can configure any remaining BFD sessions with a receive interval that is greater than or equal to the 200 ms default value.
TxInterval
Specifies the transmit interval in milliseconds. The default is 200 ms.
Note:
The minimum value you can configure for the transmit interval is 100 ms. You can configure a maximum of 4 BFD sessions with the minimum value for the transmit interval. You can configure any remaining BFD sessions with a transmit interval that is greater than or equal to the 200 ms default value.
Multiplier
Specifies a value for the multiplier used to calculate a receive timeout. The default is 3.
Note:
If you configure the transmit interval or the receive interval as 100 ms, you must configure a value of 4 or greater for the multiplier.
