Configure CP Limit functionality to protect the switch from becoming congested by an excess of data flowing through one or more ports.
  1. In the Device Physical View tab, select a port.
  2. In the navigation pane, expand Configuration > Edit > Port.
  3. Select General.
  4. Select the CP Limit tab.
  5. Select AutoRecoverPort.
  6. Select Apply.
CP Limit Field Descriptions
Use the data in the following table to use the CP Limit tab.
Name
Description
AutoRecoverPort
Activates or disables auto recovery of the port from action taken by CP Limit or link flap features. The default value is disabled.
