Perform this procedure to view PoE Powered Device (PD) information for remote LLDP-MED on specific ports.
- Select Port MED.
- Select the Neighbor PoE PD tab.
Neighbor PoE PD Field Descriptions
Use the data in the following table to use the Neighbor PoE PD tab.
Name |
Description |
TimeMark |
Specifies the time filter. For more information about TimeFilter, see the TimeFilter textual convention in IETF RFC 2021. |
LocalPortNum |
Specifies the port on which the remote LLDP-MED information is received. |
Index |
Specifies the particular connection instance that is unique to the remote LLDP-MED. |
PDPowerReq |
Specifies the value of the power required by a PD LLDP-MED connected remotely to the port. |
PDPowerSource |
Specifies the power source being utilized by the PD LLDP-MED.
PDPowerPriority |
Specifies the priority of the PD LLDP-MED connected remotely to the port, for more information, see RFC 3621.
