Configure system identification to specify the system name, contact person, and location of the switch.
Change the system name, configure the system contact, and configure the system location:
Switch:1>enable Switch:1#configure terminal Switch:1(config)#sys name Floor3Lab2 Floor3Lab2:1(config)#snmp-server contact http://companyname.com Floor3Lab2:1(config)#snmp-server location "12 Street, City, State, Zip"
Use the data in the following table to use the system-level commands.
Variable |
Value |
contact WORD<0–255> |
Identifies the contact person who manages the node. To include blank spaces in the contact, use quotation marks (") around the text. |
location WORD<0–255> |
Identifies the physical location of the node. To include blank spaces in the location, use quotation marks (") around the text. |
name WORD<0–255> |
Configures the system or root level prompt name for the switch. WORD<0–255> is an ASCII string from 1–255 characters (for example, LabSC7 or Closet4). |
