The following list identifies tunnel configuration limitations.
You cannot configure IPv6 CLIP addresses for IPv6-in-IPv4 tunnels. Also, you cannot configure an IPv6 CLIP interface as the source or destination endpoint of an tunnel.
You cannot configure SMLT on the switch terminating a tunnel.
Termination of tunnels on vIST peers is not supported.
