There are two configuration modes: Base Interworking Mode and Full Interworking Mode. The Base Interworking Mode is the default mode. To switch to the Full Interworking Mode, use this procedure.
Important
Important
After you change this boot flag, you must save the change to the configuration file and reboot the switch.
  1. In the navigation pane, expand Configuration > Edit > Chassis.
  2. Select the Boot Config tab.
  3. Select EnableVxlanGwFullInterworkingMode to enable Full Interworking Mode.
  4. Select Apply.
