View the OSPF area information.
  1. Enter Privileged EXEC mode:
    enable
  2. View the OSPF area information:
    show ip ospf area [vrf WORD<1-16>] [vrfids WORD<0-512>]
Switch:1>enable
Switch:1#show ip ospf area
                                                          OSPF Area - GlobalRouter
AREA_ID         STUB_AREA  NSSA          IMPORT_SUM ACTIVE_IFCNT    NSSA TRANSLATOR    NSSA TRANSLATOR    NSSA TRANSLATOR    NSSA TRANSLATOR
        ROLE            STATE           STABILITY INTERVAL       EVENTS
0.0.0.0         false      false         true       0               candidate         disabled                  40                0
STUB_COST INTRA_AREA_SPF_RUNS  BDR_RTR_CNT ASBDR_RTR_CNT LSA_CNT   LSACK_SUM
0         0                    0           0             0         0
Variable definitions
The following table defines parameters for the show ip ospf area command.
Variable
Value
vrf WORD<1-16>
Specifies a VRF by name.
vrfids WORD<0-512>
Specifies a range of VRF IDs.
