Enable VRRP Global Variables
Enable VRRP global variables to enable the VRRP function.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  1. In the navigation pane, expand Configuration > IP.
  2. Select VRRP.
  3. Select the Globals tab.
  4. Configure the required features.
  5. Select Apply.
Use the data in the following table to use the Globals tab.
Name
Description
NotificationCntl
Indicates whether the VRRP-enabled router generates SNMP traps for events.
  • enabled—SNMP traps are generated
  • disabled—no SNMP traps are sent
The default is enabled.
PingVirtualAddrEnable
Configures whether this device responds to pings directed to a virtual router IP address. The default is enabled.
