The following table defines parameters for the show isis spbm ip-multicast-route command.
Variable |
Value |
all |
Displays all IP Multicast over Fabric Connect route information. |
detail |
Displays detailed IP Multicast over Fabric Connect route information. |
group{A.B.C.D} |
Displays information on the group IP address for the IP Multicast over Fabric Connect route. |
vlan<1-4059> |
vrfWORD<1–16> |
Displays IP Multicast over Fabric Connect route information by VRF. |
vsn-isid<1–16777215> |
Displays IP Multicast over Fabric Connect route information by I-SID. |
The following table defines parameters for the show isis spb-mcast-summary command.
Variable |
Value |
count |
Displays the total number of SPB multicast entries. |
host-nameWORD<0–255> |
Displays the IP Multicast over Fabric Connect summary information by host-name. |
lspid<xxxx.xxxx.xxxx.xx-xx> |
Displays the IP Multicast over Fabric Connect summary information by LSP ID. |
