On switches that support only a single active VRF, ensure a user-defined VRF with a different name does not exist.
Perform this procedure to specify the VRF that Auto-sense uses for the SD-WAN configuration. On models that support a single active VRF, Auto-sense cannot create the dynamic SD-WAN VRF if an IP configuration already exists.
![Note](images/note.png)
If the running switch configuration includes the dynamic SD-WAN VRF and you complete this procedure, the switch renames the dynamic VRF to your specified name, and converts the configuration to static.
- In the navigation pane, expand
- Select AutoSense.
- Select the SD-WAN tab.
- In SD-WAN VRF, type the name of the VRF.
- Select Apply.
SD-WAN Field Descriptions
Use the data in the following table to use the SD-WAN tab.
Name | Description |
SD-WAN
Area Note: This field only
displays on a switch with boundary-node
abilities.
Specifies the IS-IS area, home or remote, where Auto-sense creates all ExtremeCloud SD-WAN learned tunnels. By default, Auto-sense creates SD-WAN logical interfaces in the home area. You can also configure exceptions for specific tunnels. For more information, see Configure the IS-IS Area for a Specific Tunnel. |
Sd-Wan Vrf |
Specifies the VRF name that Auto-sense uses for the SD-WAN configuration. On models that support a single active VRF, Auto-sense cannot create the dynamic SD-WAN VRF if an IP configuration already exists. |
