Perform this procedure to view inventory attributes for vendor-specific call server information.
  1. In the navigation pane, expand Configuration > Serviceability > Diagnostics > 802_1ab.
  2. Select Vendor Specific.
  3. Select the Call Server tab.
Vendor Specific Call Server Field Descriptions
Use the data in the following table to use the Call Server tab.
Name
Description
CallServerNum
Specifies the call server ID.
CallServerAddressType
Specifies the IP address type of the call server.
CallServerAddress
Specifies the IP address of the call server.
