View the IPv6 address bindings that IPSG allows.
- Select IPv6.
- Select the Source Guard Binding tab.
Source Guard Binding Field Descriptions
Use the data in the following table to use the Source Guard Binding tab.
Field |
Description |
IfIndex |
Specifies a value that uniquely identifies the port. |
IPv6Addr |
Specifies the binding entry for the IPv6 address. |
