Configure the SPB-PIM Gateway interface parameters on a VLAN.
  1. Enter VLAN Interface Configuration mode:
    enable
    configure terminal
    interface vlan <1–4059>
  2. Configure the SPB-PIM Gateway VLAN HELLO interval:
    ip spb-pim-gw hello-interval <0-18724>
  3. Configure the SPB-PIM Gateway VLAN JOIN PRUNE interval:
    ip spb-pim-gw ip join-prune-interval <1-18724>
Variable definitions
The following table defines parameters for the ip spb-pim-gw command.
Variable
Value
hello-interval<0-18724>
Specifies the HELLO interval in seconds. The default value is 30 seconds.
join-prune-interval<1-18724>
Specifies the JOIN PRUNE interval in seconds. The default value is 60 seconds.
