View topology message status to view the interconnections between Layer 2 devices in a network.
  1. To enter User EXEC mode, log on to the switch.
  2. Show the contents of the topology table:
    show autotopology nmm-table
    Unless the switch is physically connected to other devices in the network, this topology will be blank.
In the following example, the column “ChassisType” uses a generic name. When you use the show autotopology nmm-table, your switch displays the actual chassis type.
Switch:1(config)#show autotopology nmm-table
                                      Topology Table
Local        Rem
Port     IpAddress       SegmentId MacAddress   ChassisType            BT LS  CS   Port
0/0      192.0.2.81     0x000000  0030ab707a00 ChassisType 1          12 Yes HtBt  0/0
1/1      192.0.2.81     0x000000  0050ea268800 ChassisType 2          12 Yes HtBt  1/12
1/24     192.0.2.81     0x000000  070ab307aa00 ChassisType 3          12 Yes HtBt  1/1
2/1      192.0.2.81     0x000000  0030ab57ab00 ChassisType 4          12 Yes HtBt  1/23
2/2      192.0.2.81     0x000000  0030ab307af0 ChassisType 5          12 Yes HtBt  1/12
When a peer switch is running an older software version that does not include support for SONMP hello messages with channelization information, it can only show the slot/port. It cannot show the sub-port.
