Configure IPv6 PIM on a Port or VLAN
Configure PIM for each interface to enable the interface to perform multicasting operations.
  • Enable IPv6 interface.
  1. Enter Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]} or interface vlan <1–4059>
  2. Create a PIM interface on a port or VLAN:
    ipv6 pim enable
    This command creates an active interface, by default.
  3. Configure the interval for join and prune messages:
    ipv6 pim join-prune-interval <1–18724>
  4. Configure the time between hello messages:
    ipv6 pim hello-interval <0–18724>
Switch:1(config-if)#ipv6 pim join-prune-interval 60
Switch:1(config-if)#ipv6 pim hello-interval 30
The following table describes the variables for the ipv6 pim command.
Variable
Value
hello-interval <0-18724>
Specifies the duration in seconds before the PIM router sends out the next hello message to neighboring switches.
The default value is 30 seconds.
join-prune-interval <1-18724>
Specifies the duration in seconds before the PIM router sends out the next join or prune message to its upstream neighbors.
The default value is 60 seconds.
