Configure a redistribute entry to announce certain routes into the RIPng domain, including static routes, direct routes, Open Shortest Path First (OSPFv3), IS-IS, or Border Gateway Protocol (BGP+).
Enable RIPng globally.
Enable the redistribution instance.
Switch:1#enable Switch:1#configure terminal Switch:1(config)#router rip Switch:1(config-rip)#ipv6 redistribute bgp enable Switch:1(config-rip)#ipv6 redistribute direct enable Switch:1(config-rip)#ipv6 redistribute isis enable Switch:1(config-rip)#ipv6 redistribute ospf enable Switch:1(config-rip)#ipv6 redistribute static enable Switch:1(config-rip)#show ipv6 rip redistribute ================================================================================ RIPng Redistribute List ================================================================================ direct : enabled static : enabled ospf : enabled bgp : enabled isis : enabled --------------------------------------------------------------------------------
Variable definitions
Use the data in the following table to use the ipv6 redistribute command.
Variable |
Value |
<bgp|direct|isis|ospf|static> |
Specifies the type of routes to redistribute (the protocol source). Valid options are bgp, isis, direct, ospf, or static. |
