You must enable DAI separately for each VLAN. When you enable DAI on a specific VLAN, the ARP packets are captured and inspected on that VLAN. DAI is disabled by default.
DAI cannot be enabled on Private VLANs (E-Tree) and SPBM B-VLANs.
You must enable DHCP Snooping globally.
  1. Enter VLAN Interface Configuration mode:
    enable
    configure terminal
    interface vlan <1–4059>
  2. Enable DAI on the VLAN:
    ip arp-inspection enable
  3. Disable DAI on the VLAN:
    no ip arp-inspection enable
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface vlan 5
Switch:1(config-if)#ip arp-inspection enable
The following table defines parameters for the ip arp-inspection command.
Variable
Value
enable
Enables or disables DAI on the specified VLAN.
