Configure an ACE IP protocol
Configure ACE IP protocol entries to have the filter look for packets of specific protocols.
The ACL exists.
The ACE exists.
- Select Advanced Filters (ACE/ACLs).
- Select the ACL tab.
- Select the appropriate ACL.
- Select ACE.
- Select the appropriate ACE.
- Select IP.
- Select the Protocol tab.
- Select Insert.
- Specify the operation type.
- In the List box, enter the IP protocol type.
- Select Insert.
Protocol Field Descriptions
Use the data in the following table to use the Protocol tab.
Name |
Description |
AclId |
Specifies the ACL ID. |
AceId |
Specifies the ACE ID. |
Oper |
The eq parameter specifies an operator for a field match condition: equal to. |
List |
Specifies the IP protocol type. Entries include 0–256, undefined, tcp, udp, ipsecesp, vrrp, and undefined. |
