To enable the SSH client functionality, you must enable SSH globally.
You can disable the SSH client functionality on the switch. By default, the SSH client functionality is enabled.
    enable
    configure terminal
  2. Enable or disable the SSH client functionality:
    • To disable the client, enter the following command:no ssh client enable
    • To enable the client, enter the following command: ssh client enable
