If the agent IP address is a VLAN or port IP address, you must enable DHCP Relay on that VLAN or port within the VLAN context. However, if the agent IP address is a VRRP address, you do not need to enable DHCP Relay on the VLAN or port in which the VRRP address resides.
After you configure the BOOTP/DHCP relay on an IP interface, you can configure forwarding paths to indicate where packets are forwarded. The forwarding paths are based on the type of packet and where the packet is received.
Use the data in the following table to use the Globals tab.
Name |
Description |
AgentAddr |
Specifies the IP address of the input interface (agent) on which the BOOTP/DHCP request packets are received for forwarding. You cannot specify a Secondary IP Interface address as the agent IP address in the forwarding path. To make DHCP aware of Secondary IP Interfaces, you must enable DHCP Smart Relay. |
ServerAddr |
This parameter is either the IP address of the BOOTP/DHCP server or the address of another local interface.
Enable |
Enables BOOTP/DHCP relay. |
Mode |
Specifies the type of messages relayed:
The default is to forward both BOOTP and DHCP messages. |
SrcPort67 |
Assigns source port 67 to the UDP forwarding path. The default is source port 68. |
