View Chassis TCP Statistics
View TCP statistics to monitor network performance.
  1. In the navigation pane, expand Configuration > Graph.
  2. Select Chassis.
  3. Select the TCP tab.
TCP Field Descriptions
The following table describes parameters on the TCP tab.
Name
Description
ActiveOpens
The number of times TCP connections made a direct transition to the SYN-SENT state from the CLOSED state.
PassiveOpens
The number of times TCP connections made a direct transition to the SYN-RCVD state from the LISTEN state.
AttemptFails
The number of times TCP connections made a direct transition to the CLOSED state from either the SYN-SENT state or the SYN-RCVD state, plus the number of times TCP connections made a direct transition to the LISTEN state from the SYN-RCVD state.
EstabResets
The number of times TCP connections made a direct transition to the CLOSED state from either the ESTABLISHED state or the CLOSE-WAIT state.
CurrEstab
The number of TCP connections for which the current state is either ESTABLISHED or CLOSE-WAIT.
InSegs
The number of segments received, including those received in error. This count includes segments received on currently established connections.
OutSegs
The number of segments sent, including those on current connections, but excluding those containing only retransmitted octets.
RetransSegs
The number of segments retransmitted that is, the number of TCP segments transmitted containing one or more previously transmitted octets.
InErrs
The number of segments received in error (for example, bad TCP checksums).
OutRsts
The number of TCP segments sent containing the RST flag.
HCInSegs
The number of segments received, including those received in error. This count includes segments received on currently established connections. This object is the 64-bit equivalent of InSegs.
HCOutSegs
The number of segments sent, including those on current connections, but excluding those containing only retransmitted octets. This object is the 64-bit equivalent of OutSegs.
