Configure the Spanning Tree mode to change the mode to MSTP or RSTP mode.
![Important](images/important.png)
Important
After you change the mode, save the configuration, and then restart the system for the changes to take effect.
- Select Globals.
- Select the required spanning tree mode.
- Select Apply.
Use the data in the following table to use the Globals tab.
Name |
Description |
SpanningTreeAdminMode |
Configures the spanning tree mode as either RSTP or MSTP. The default is MSTP. |
SpanningTreeOperMode |
Specifies the current mode of the spanning tree. |
