View the link-local advertisements for each virtual interface in the link-state database.
  1. In the navigation pane, expand Configuration > IP.
  2. Select OSPF.
  3. Select the Local Lsdb tab.
Local Lsdb Field Descriptions
Use the data in the following table to use the Local Lsdb tab.
Name
Description
IpAddress
Specifies the IP address of the interface from which the link-state advertisement was received if the interface is numbered.
AddressLessIf
Specifies the interface index of the interface from which the LSA was received if the interface is unnumbered.
Type
Specifies the type of the link-state advertisement.
Lsid
Specifies the piece of the routing domain that the advertisement describes.
RouterId
Specifies the originating router in the Autonomous System.
Sequence
Identifies old and duplicate link-state advertisements.
Age
Specifies the age, in seconds, of the link-state advertisement.
Checksum
Contains the checksum of the complete contents of the advertisement, except for the age parameter. The checksum does not include the age parameter so that advertisement age increments without updating the checksum.
Advertisement
Specifies the size of the entire link-state advertisement.
