Use this procedure to display MLD snooping interface parameters.
Switch:1>show ipv6 mld interface ========================================================================================== Mld Interface - GlobalRouter ========================================================================================== IF STATUS VERS OPER VERS QUERIER Wrong Query JOINS MODE ------------------------------------------------------------------------------------------ P1/3 inact 2 2 2001:0db8:3c4d:0015:0000:0000:1a2f:1aaa 0 0 pim V666 inact 2 2 2001:0db8:3c4d:0015:0000:0000:1a2f:1bbb 0 0 pim Switch:1>show ipv6 mld interface vlan 10 ================================================================================ Vlan IPv6 Mld ================================================================================ VLAN QUERY QUERY ROBUST VERSION LAST SNOOP SSM DYNAMIC ID INTVL MAX LIST ENABLE SNOOP DOWNGRADE RESP QUERY ENABLE -------------------------------------------------------------------------------- 10 125 10 2 1 1 false false enabled Switch:1>show ipv6 mld interface gigabitethernet 1/11 ================================================================================ Port IPv6 MLD ================================================================================ PORT QUERY QUERY ROBUST VERSION LAST DYNAMIC NUM INTVL MAX LIST DOWNGRADE RESP QUERY -------------------------------------------------------------------------------- 1/11 125 10 2 1 1 enabled 1 out of 1 entries displayed
The following table describes the variables for the show ipv6 mld interface command.
Variable | Value |
vlan <1-4059> |
Displays MLD snooping information for the configured VLANs. |
gigabitEthernet {slot/port[/sub-port]} |
Displays MLD snooping information on a specific interface. |
