Use the following procedure to display the SPB-PIM Gateway VLAN interface information.
Switch:1>show ip spb-pim-gw interface ============================================================================================= Spb-pim-gw Interface - GlobalRouter ============================================================================================= IF ADDR MASK JPINT HELLOINT OPSTATE ADMINSTATE Vlan50 50.1.1.1 255.255.255.0 60 30 Disabled Enabled Vlan123 123.1.1.1 255.255.255.0 60 30 Disabled Disabled Vlan142 142.1.1.1 255.255.255.0 60 30 Enabled Enabled Vlan400 100.1.1.2 255.255.255.0 60 30 Disabled Disabled Total spb-pim-gw Interfaces Displayed 4/4
Variable definitions
The following table defines parameters for the show ip spb-pim-gw interface command.
Variable |
Value |
vlan-id |
The VLAN ID of an interface to display. |
