Configure MLD Globally
Use the following procedure to configure MLD parameters for the switch.
- Select IPv6 MLD.
- Select the Globals tab.
- Configure the MLD global parameters as required.
- Select Apply to save the changes.
- Select Refresh to update the changes.
Globals Field Description
Use the data in the following table to use the Globals tab.
Field |
Description |
GenerateTrap |
Enables MLD to generate traps. |
GenerateLog |
Enables MLD to generate logs. |
