Configure IGMP fast leave members on a VLAN to specify fast leave capable ports.
  1. Enter VLAN Interface Configuration mode:
    enable
    configure terminal
    interface vlan <1–4059>
  2. Enable fast leave on the VLAN:
    ip igmp immediate-leave
  3. Configure fast leave members on a VLAN:
    ip igmp immediate-leave-members {slot/port[/sub-port][-slot/port[/sub-port]][,...]}
Variable definitions
Use the data in the following table to use the ip igmp immediate-leave-members command.
Variable
Value
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
