View tunnel interfaces to verify the current configuration and operational status of IPv6 tunnels.
Switch:1#show ipv6 tunnel detail ================================================================================ Tunnel Interface Information ================================================================================ ID LOCAL ADDRESS REMOTE ADDRESS OPER STATUS TYPE -------------------------------------------------------------------------------- 2 211.1.55.2 44.1.55.1 active manual 1 211.1.55.2 44.1.55.43 active manual 210 211.1.60.2 47.1.60.1 active manual 3 out of 3 Total number of entries displayed. -------------------------------------------------------------------------------- ================================================================================ Address Information ================================================================================ IPV6 ADDRESS/PREFIX LENGTH TYPE ORIGIN STATUS -------------------------------------------------------------------------------- 43:210:0:0:0:0:0:2/64 UNICAST MANUAL PREFERRED fe80:0:0:0:0:0:d301:3702/64 UNICAST LINKLAYER PREFERRED 44:211:0:0:0:0:0:2/64 UNICAST MANUAL PREFERRED fe80:0:0:0:0:0:d301:3702/64 UNICAST LINKLAYER PREFERRED
Variable definitions
Use the data in the following table to use the show ipv6 tunnel command.
Variable | Value |
<1–2000> | Shows information for a specific tunnel ID. |
detail | Shows detailed address information for the tunnel. |
local {A.B.C.D} | Shows information for a specific local address (the local endpoint of the tunnel). |
remote {A.B.C.D} | Shows information for a specific remote address (the remote endpoint of the tunnel). |
