Enable channelization on a port to configure it to operate as four channels, or ports.
The switch automatically channelizes a port if the port operates in Auto-sense mode and you insert a QSFP+ to SFP+ or QSFP28 to SFP28 adapter, or a breakout cable.
Important
Important
Enabling or disabling channelization resets the port QoS configuration to default values.
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Enable channelization on a port:
    channelize [port {slot/port[-slot/port][,...]}] enable
  3. Display the status of the ports:
    show interfaces gigabitEthernet channelize [{slot/port[-slot/port][,...]}]
    To display the details of the sub-ports, use:
    show interfaces gigabitEthernet channelize detail [{slot/port/sub-port[-slot/port/sub-port][,...]}]
Switch:1> enable
Switch:1# configure terminal
Switch:1(config)# interface gigabitethernet 2/1
Switch:1(config-if)# channelize enable
Enabling channelization on port 2/1. Subport 2/1/1 will inherit port 2/1 configuration. Subports 2,3,4 will use default config. QSFP will be reset as removal and re-insert.
    NOTE: Modify QOS configurations on all subports as required.
Do you wish to continue (y/n) ? y
Display the port status:
Switch:1(config)# show interfaces gigabitEthernet channelize 2/1-2/2
                              Port Channelization
PORT         ADMIN MODE     CHANNEL TYPE
2/1          true           40G
2/2          true           40G
The following is an example of how to disable channelization on a port:
Switch:1> enable
Switch:1(config)# interface gigabitethernet 2/1/1
Switch:1(config-if)# no channelize enable
The following table defines parameters for the channelization command.
Variable
Value
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
