Enable FHS globally for ND inspection to work.
Use this procedure to enable Neighbor Discovery inspection on a port
  1. Enter GigabitEthernet Interface Configuration mode:
    enable
    configure terminal
    interface GigabitEthernet {slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
  2. Enable Neighbor Discovery inspection on the port:
    ipv6 fhs nd-inspection enable
