Enable SPB-PIM Gateway on a Brouter port.
  1. In the Device Physical View tab, select the port you need to configure.
  2. In the navigation pane, expand Configuration > Edit > Port.
  3. Select IP.
  4. Select the SPB-PIM-GW tab.
  5. Select Enable.
  6. Select Apply.
SPB-PIM-GW Field Descriptions
Use the data in the following table to use the SPB-PIM-GW tab.
Name
Description
Enable
Enables SPB-PIM Gateway on the interface. The default is disabled.
OperState
Displays the current operational state of this SPB-PIM Gateway interface.
Address
Displays the primary IP address of this router on this SPB-PIM Gateway interface.
AddressMask
Displays the primary IP address mask of this router on this SPB-PIM Gateway interface.
HelloInterval
Configures the PIM HELLO transmission interval.
JoinPruneInterval
Configures the PIM JOIN PRUNE transmission interval.
