Clear the MSDP SA Cache
Clear the SA cache to clear the SA entries the router learns from all the peers or a specific peer.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
  1. In the navigation pane, expand Configuration > IP.
  2. Select MSDP.
  3. Select the SA-Cache tab.
  4. Select Clear SA-Cache.
SA-Cache Field Descriptions
Use the data in the following table to use the SA-Cache tab.
Name
Description
GroupAddr
Shows the group IP address of the SA cache entry.
SourceAddr
Shows the source IP address of the SA cache entry.
OriginRP
Shows the RP address of the SA cache entry.
PeerLearnedFrom
Shows the peer from which this SA cache entry was accepted.
RPFPeer
Shows the peer from which an SA message corresponding to the cache entry is accepted.
InSAs
Discontinuities in the value of this counter can occur at reinitialization of the management system.
InDataPackets
Shows the number of MSDP encapsulated data packets received that are relevant to this cache entry.
UpTime
Shows the time since this entry was first placed in the SA cache.
ExpiryTime
Shows the time remaining before this entry expires from the SA cache.
