Configure a queue profile to apply the configured egress queue parameters to queues and ports. You must apply the profile before the changes take effect.
The switch supports six queue profiles. The default queue profile, with the name default and ID 1, is automatically created during system startup and cannot be deleted.
- Select Queue Profile.
- Select the Queue Profile tab.
- Select Insert.
- In Id, type the queue profile value.
- Optional: In Name, specify a name for the queue profile.
- To add a port to this queue, select the PortList ellipsis (...), choose a port or ports, and then selects Ok.
- Select Apply.
- Select Insert.
Queue Profile Field Descriptions
Use the data in the following table to use the Queue Profile tab.
Field |
Description |
Id |
Specifies the ID for the queue profile. |
Name |
Specifies the queue profile name. |
Apply |
Applies the queue profile. |
PortList |
Indicates the port members of the queue profile. |
