Associate a Port and MLT with an I-SID for ELAN
Use the following procedure to associate a port and MLT with an I-SID.
You must configure Switched UNI.
- Select ISID.
- On the Service tab, select a row with the type configured as elan.
- Select Switched Uni.
- Select Insert.
- Enter the VLAN ID in the Cvid field.
- Select Port or Mlt to update the interface index in the IfIndex field.
- Select Insert.
Switched Uni Field Descriptions
Use the data in the following table to use the Switched Uni tab.
Name |
Description |
Isid |
Displays the I-SID. |
Cvid |
Specifies the customer VLAN identifier. |
IfIndex |
Specifies the interface index of the ELAN end point. |
Bpdu |
Enables or disables for an untagged end point. The default is disabled. |
OriginBitmap |
Specifies the origin information of the service associated with the I-SID ELAN end point. |
MacBased |
Shows if the current entry is associated to a MAC-based Switched User Network Interface (S-UNI). |
