Use this task to view IP ICMP statistics for a Segmented Management Instance.
- Select Mgmt Instance.
- Select Stats.
- Select the IP-ICMP tab.
- To clear IP statistics, select Clear Stats.
- To clear IP counters, select Clear Counters.
IP-ICMP Field Descriptions
Use the data in the following table to use the IP-ICMP tab.
Name |
Description |
InMsgs |
Shows the inbound messages statistics. |
InErrors |
Shows the inbound errors statistics. |
InCsumErrors |
Shows the inbound checksum errors statistics. |
InDestUnreachs |
Shows the inbound destination unreachable statistics. |
InTimeExcds |
Shows the inbound time exceeded statistics. |
| InParmProbs |
Shows the inbound parameter problems statistics. |
| InSrcQuenchs |
Shows the inbound source quenchs statistics. |
| InRedirects |
Shows the inbound redirects statistics. |
| InEchos |
Shows the inbound echos statistics. |
| InEchoReps |
Shows the inbound echo replies statistics. |
| InTimestamps |
Shows the inbound timestamps statistics. |
| InTimestampsReps |
Shows the inbound timestamp replies statistics. |
| InAddrMasks |
Shows the inbound address masks statistics. |
| InAddrMaskReps |
Shows the inbound address mask replies statistics. |
| OutMsgs |
Shows the outbound messages statistics. |
| OutErrors |
Shows the outbound errors statistics. |
| OutDestUnreachs |
Shows the outbound destination unreachable statistics. |
| OutTimeExcds |
Shows the outbound time exceeded statistics. |
| OutParmProbs |
Shows the outbound parameter problems statistics. |
| OutSrcQuenchs |
Shows the outbound source quenchs statistics. |
| OutRedirects |
Shows the outbound redirects statistics. |
| OutEchos |
Shows the outbound echos statistics. |
| OutEchoReps |
Shows the outbound echo replies statistics. |
| OutTimestamps |
Shows the outbound timestamps statistics. |
| OutTimestampReps |
Shows the outbound timestamps replies statistics. |
| OutAddrMasks |
Shows the outbound address masks statistics. |
| MsgInType0 |
Shows the inbound Type0 messages statistics. |
| MsgOutType8 |
Shows the outbound Type8 messages statistics. |
