Use this procedure to enable FHS to enable DHCPv6 Guard, RA Guard, and ND-inspection globally, and to configure the lifetime for these policies.
- From the navigation pane, expand .
- Select FHS.
- Select the Globals tab.
- Select FHS global options.
- Select Apply to save the changes.
- Optional: Select Refresh to update the results.
Use the data in the following table to use the Globals tab.
Name |
Description |
Admin |
Enables or disables the FHS policy. |
RAGuardAdmin |
Enables or disables the RA Guard policy. |
DHCPv6GuardAdmin |
Enables or disables the DHCPv6 Guard policy. |
NdInspectAdmin |
Enables or disables Neighbor Discovery inspection. |
