    enable
    configure terminal
  2. Configure the type of encryption to use:
    ssh encryption-type {[3des-cbc][aead-aes-128-gcm-ssh ][aead-aes-256-gcm-ssh] [aes128-cbc][aes128-ctr][aes192-cbc][aes192-ctr][aes256-cbc][aes256-ctr][blowfish-cbc] [rijndael128-cbc][rijndael192-cbc]}
The following table defines parameters for the ssh encryption-type command.
Variable Value
Configures the encryption-type. Select an encryption-type from one of the following:
  • 3des-cbc
  • aead-aes-128-gcm-ssh
  • aead-aes-256-gcm-ssh
  • aes128-cbc
  • aes128-ctr
  • aes192-cbc
  • aes192-ctr
  • aes256-cbc
  • aes256-ctr
  • blowfish-cbc
  • rijndael128-cbc
  • rijndael192-cbc
By default, all encryption types are enabled.
If you configure the switch in Enhanced Secure Mode, 3des-cbc and blowfish-cbc are disabled by default.
