Perform the following procedure to display the RSTP-related configuration information for the selected port.
  1. Enter Privileged EXEC mode:
    enable
  2. Display the RSTP information for a selected port:
    show spanning-tree rstp port statistics [{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}]
Switch:1# show spanning-tree rstp port statistics 1/4
                       RSTP Port Statistics
Port Number                       : 1/4
Number of Fwd Transitions         : 0
Rx RST BPDUs Count                : 0
Rx Config BPDU Count              : 0
Rx TCN BPDU Count                 : 0
Tx RST BPDUs Count                : 9
Tx Config BPDU Count              : 0
Tx TCN BPDU Count                 : 0
Invalid RST BPDUs Rx Count        : 0
Invalid Config BPDU Rx Count      : 0
Invalid TCN BPDU Rx Count         : 0
Protocol Migration Count          : 0
Variable definitions
Use the data in the following table to use optional parameters with the show spanning-tree rstp port statistics command.
Variable
Value
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
