On disabling the ICMP broadcast processing, all the packets containing ICMP sent to broadcast addresses, will be dropped when they reach the control plane.
Use these commands to enable or disable the IPv4 ICMP broadcast feature on the global router.
    enable
    configure terminal
  2. Enable IPv4 ICMP broadcast feature, enter:
    ip icmp echo-broadcast-request
  3. Disable IPv4 ICMP broadcast feature, enter:
    no ip icmp echo-broadcast-request
  4. Set the IPv4 ICMP broadcast feature to default state, enter:
    default ip icmp echo-broadcast-request
    By default, the IPv4 ICMP broadcast feature is enabled.
  5. View the IPv4 ICMP broadcast feature state:
    show ip routing
