Use statistics to help you monitor OSPF performance on a VLAN. You can also graph statistics for all OSPF packets.
- On the Device Physical View, select a port.
- Select IP.
- Select the OSPF tab.
- Select Graph.
- Select one or more values.
- Select the type of graph.
OSPF Field Descriptions
Use the data in the following table to use the OSPF tab.
Name |
Description |
VersionMismatches |
Indicates the number of version mismatches received by this interface. |
AreaMismatches |
Indicates the number of area mismatches received by this interface. |
AuthTypeMismatches |
Indicates the number of AuthType mismatches received by this interface. |
AuthFailures |
Indicates the number of authentication failures. |
NetMaskMistmatches |
Indicates the number of net mask mismatches received by this interface. |
HelloIntervalMismatches |
Indicates the number of hello interval mismatches received by this interface. |
DeadIntervalMismatches |
Indicates the number of dead interval mismatches received by this interface. |
OptionMismatches |
Indicates the number of options mismatches received by this interface. |
RxHellos |
Indicates the number of hello packets received by this interface. |
RxDBDescrs |
Indicates the number of database descriptor packets received by this interface. |
RxLSUpdates |
Indicate the number of Link state update packets received by this interface. |
RxLsReqs |
Indicates the number of Link state request packets received by this interface. |
RxLSAcks |
Indicates the number of Link state acknowledge packets received by this interface. |
TxHellos |
Indicates the number of hello packets transmitted by this interface. |
TxDBDescrs |
Indicates the number of database descriptor packets transmitted by this interface. |
TxLSUpdates |
Indicate the number of Link state update packets transmitted by this interface. |
TxLSReqs |
Indicates the number of Link state request packets transmitted by this interface. |
TxLSAcks |
Indicates the number of Link state acknowledge packets transmitted by this interface. |
