View the OSPF configuration information.
Switch:1>show ip ospf accept ================================================================================ Ospf Accept - GlobalRouter ================================================================================ ADV_RTR MET_TYPE ENABLE POLICY -------------------------------------------------------------------------------- 192.0.2.11 type1 true test1
Variable definitions
UThe following table defines parameters for the show ip ospf accept command.
Variable |
Value |
vrf WORD<1-16> |
Specifies a VRF by name. |
vrfids WORD<0-512> |
Specifies a range of VRF IDs. |
