Configure a circuitless IP (CLIP) interface to provide a virtual interface that is not associated with a physical port. You can use a CLIP interface to provide uninterrupted connectivity to your device.
For scaling information and for information on the maximum number of CLIP interfaces you can configure on your device, see Fabric Engine Release Notes.
Create a CLIP interface.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#interface loopback 3
Switch:1(config-if)#ip address 23.23.23.23 255.255.255.0 name ExtNet
Switch:1>show ip interface
IP Interface - GlobalRouter
INTERFACE IP NET ADMIN OPER VLAN BROUTER IPSEC IP
ADDRESS MASK STATUS STATUS ID PORT STATE NAME
Port1/2 10.3.4.2 255.255.255.0 enable up 3 true disable address1
Clip1 1.2.3.4 255.255.0.0 enable up -- false disable
Clip2 2.3.4.5 255.255.255.0 enable up -- false disable
Clip23 23.23.23.23 255.255.255.0 enable up -- false disable ExtNet
Vlan2 192.0.2.5 255.255.255.0 enable up 2 false disable
Vlan55 55.55.55.55 255.255.255.0 enable up 55 false disable Boston
All 6 out of 6 Total Num of IP interfaces displayed
Use the data in the following table to use the ip commands.
Variable |
Value |
address [ <1-256> ] <A.B.C.D/X> [vrf WORD<1-16> ][name WORD<0-64] |
Specifies the IP address for the CLIP interface. <1-256> specifies the interface. <A.B.C.D/X> specifies the IP address and mask (0–32). vrf WORD<1-16> specifies an associated VRF by name. The no form of this command is no ip address [<1-32>] <A.B.C.D> [vrf WORD<1-16>]. name WORD<1-16> specifies a name for the IP address. |
area <1-256> <A.B.C.D> [vrf WORD<1-16> ] |
Designates an area for the CLIP interface. vrf WORD<1-16> specifies an associated VRF by name The default form of this command is default ip area <1-256> <A.B.C.D> [vrf WORD<1-16>]. The no form of this command is no ip area <1-256> vrf WORD<1-16>]. |
