View the LSDB to determine externally learned routing information. The system displays the information for all metric types or for the type you specify.
Switch:1#show ip ospf ase
OSPF AsExternal Lsas - GlobalRouter
LSTYPE LINKSTATEID ADV_ROUTER ETYPE METRIC ASE_FWD_ADDR AGE SEQ_NBR CSUM
Variable definitions
The following table defines parameters for the show ip ospf ase command.
Variable |
Value |
metric-type <1-2> |
Specifies the metric type. |
vrf WORD<1-16> |
Identifies the VRF by name. |
vrfids WORD<0-512> |
Specifies a VRF by ID. |
