Configure up to 10 NTP authentication keys to use MD5 or SHA1 authentication.
Switch:1>enable
Switch:1#configure terminal
Switch:1(config)#ntp authentication-key 5 type md5
Enter the NTP secret key: ******
Reenter the NTP secret key: ******
Switch:1(config)#ntp server 192.0.2.187 auth-enable
Switch:1(config)#ntp server 192.0.2.187 authentication-key 5
Switch:1(config)#show ntp key
NTP Key
Key_Id Type
5 MD5
10 SHA1
20 MD5
30 SHA1
100 MD5
The following table defines parameters for the ntp and ntp server commands.
Variable |
Value |
auth-enable |
Activates MD5 or SHA1 authentication on this NTP server. The default is no authentication. |
authentication-key <0-65534> |
Specifies the key ID value used to generate the MD5 or SHA1 digest for the NTPv4 server. The default value is 0, which indicates disabled authentication. |
type <md5|sha1> |
Specifies the type of authentication, whether MD5 or SHA1. The default is MD5 authentication. |
WORD<1–110> |
Specifies the IPv4 address, IPv6 address, or fully qualified domain name (FQDN) of the NTP server. If you use an FQDN, you must also configure the switch to use DNS. |
