If required, configure a route policy.
When you configure BGP on a specific VRF instance, the VRF must have an RP trigger of BGP.
To perform this procedure on a non-default VRF, you must first change the VRF instance. For information about how to use EDM for a non-default VRF, see Select and Launch a VRF Context View. All parameters might not be available in non-default VRFs.
Before you redistribute DvR host routes to BGP, ensure that you disable BGP aggregation and BGP auto-summarization of networks. Disabling these options ensures that all DvR host routes are advertised into BGP correctly, and are not summarized.
Configure redistribute entries for BGP to announce routes of a certain source type to BGP, for example, DvR, direct, static, Routing Information Protocol (RIP), and Open Shortest Path First (OSPF). If you do not configure a route policy, then the switch uses the default action based on metric, metric type, and subnet. Use a route policy to perform detailed redistribution.
- Select BGP.
- Select the Redistribute tab.
- Select Insert.
- Configure the source protocol.
- Optional: If required, choose a route policy.
- Configure the metric to apply to redistributed routes.
- Optional: Select AutoFilterTag to enable route filtering using tags.
- Enable the redistribution instance.
- Select Insert.
Redistribute Field Descriptions
Use the data in the following table to use the Redistribute tab.
Name |
Description |
DstVrfId |
Specifies the destination VRF instance (read-only). |
Protocol |
Specifies the protocols that receive the redistributed routes. |
SrcVrfId |
Specifies the source VRF instance (read-only). |
RouteSource |
Specifies the source protocol for the route redistribution entry. |
Enable |
Enables (or disables) a BGP redistribute entry for a specified source type. |
RoutePolicy |
Configures the route policy to use for the detailed redistribution of external routes from a specified source into the BGP domain. |
Metric |
Configures the metric for the redistributed route. The default value is 0. Use a value that is consistent with the destination protocol. |
| MetricType |
Configures the metric type to apply to redistributed routes. When you enable the live-metric option, when BGP redistributes static, RIP, OSPF, IS-IS, or DvR routes, the metric value is taken from the routing table and is set to the Path attributes as a MED value. By default, this option is disabled, which means the BGP MED value is not derived from the metric in the routing table. |
| AutoFilterTag |
Enables route filtering to ensure tagged routes are not redistributed into BGP. The default is disabled. |
