Configure the notify table to select management targets to receive notifications, as well as the type of notification to send to each management target.
  • For more information about the notify filter table, see RFC3413.
    enable
    configure terminal
  2. Create a new notify filter table:
    snmp-server notify-filter WORD<1-32> WORD<1-32>
  3. Ensure that the configuration is correct:
    show snmp-server notify-filter
Switch:1(config)#snmp-server notify-filter profile3 99.3.6.1.6.3.1.1.4.1
Switch:1(config)#show snmp-server notify-filter
                          Notify Filter Configuration
Profile Name                     Subtree                           Mask
profile1                         +99.3.6.1.6.3.1.1.4.1             0x7f
profile2                         +99.3.6.1.6.3.1.1.4.1             0x7f
profile3                         +99.3.6.1.6.3.1.1.4.1             0x7f
The following table defines parameters for the snmp-server notify-filter command.
Variable
Value
Creates a notify filter table.
The first instance of WORD<1-32> specifies the name of the filter profile with a string length of 1–32.
The second instance of WORD<1-32> identifies the filter subtree OID with a string length of 1–32.
If the subtree OID parameter uses a plus sign (+) prefix (or no prefix), this indicates include. If the subtree OID uses the minus sign ( – ) prefix, it indicates exclude.
You do not calculate the mask because it is automatically calculated. You can use the wildcard character, the asterisk (*), to specify the mask within the OID. You do not need to specify the OID in the dotted decimal format; you can alternatively specify that the MIB parameter names and the OIDs are automatically calculated.
