This topic explains how to obtain, activate, and transfer licenses on universal hardware switches.
Obtain and Install a License
For universal hardware switches, you can activate a license on the switch using either of the following methods:
To obtain and install a license, follow these steps:
You should have received by email a license voucher after your purchase of a switch. You will need the voucher ID number on this email to generate a license.
For manual license generation and installation:
  1. Upgrade the switch so that it is running the most recent GA version of the software.
    To download the latest GA software, visit the Extreme Networks Support portal.
  2. Follow manual activation instructions for license generation available on the Extreme Networks Support portal: Products > ExtremeSwitching > Universal > Fabric Engine (VOSS) (for your switch) > Activation Instructions.
  3. Download the license file onto the switch.
  4. Install the license, using the command load-license license_filename.
The software verifies the license and activates the features that correspond to the license category.
For more information, see either of the following:
Transfer a License
You can permanently remove a license, which allows you to transfer the license to another switch. This should only be done when preparing to return a defective switch for a replacement switch (RMA).
To transfer a license from a defective switch to a replacement switch (RMA), follow these steps.
  1. Go to the Extreme Networks Support portal.
  2. Select Assets > Licenses Home.
  3. Select License Transfer.
  4. Enter the serial number of the defective unit, replacement unit serial number, and the RMA/case number.
  5. Generate the new license, following the process in step 2 in Obtain and Install a License.
  6. Download the license file onto the switch.
  7. Install the license, using the command load-license license_filename.
