The policy must exist before you can name it.
Assign a name to an existing access policy to uniquely identify the policy.
    enable
    configure terminal
  2. Assign a name to the access policy:
    access-policy <1-65535> name WORD<0–15>
Assign a name to an access policy:
Switch:1>enable
Switch:1#configure terminal
Enter configuration commands, one per line.  End with CNTL/Z.
Switch:1(config)#access-policy 10 name useraccounts
The following table defines parameters for the access-policy command.
Variable
Value
name WORD<0–15>
Specifies a name expressed as a string from 0–15 characters.
